the priorities are randomized every time the scenario is opened. If the priorities are specified in the XML file then this order will be used. So far the only way to change them is to edit the file. Note that modifying and re-saving the scenario will probably result in a loss of the manual modification.
-J
realtime and delay
Re: realtime and delay
Changing the attributes + saving + loading does save the priorities
