realtime and delay
Come here to discuss about OpenViBE in general!
jlegeny
Contact:
Re: realtime and delay
Post by jlegeny »
Hello,
the priorities are randomized every time the scenario is opened. If the priorities are specified in the XML file then this order will be used. So far the only way to change them is to edit the file. Note that modifying and re-saving the scenario will probably result in a loss of the manual modification.
-J
yrenard
Site Admin
Contact:
Post by yrenard »
Changing the attributes + saving + loading does save the priorities :)
Best regards,
Yann
Post Reply
