OpenViBE uses Ogre version 1.7.1, as the Ogre API changes very frequently, even for minor revisions it is quite possible that it will not work with ulterior versions.
Can you post the output of your linux-build to know where it fails, also, does the linux-install-dependencies script output any error?
trouble building openvibe on linux
Re: trouble building openvibe on linux
there is one line that indicate a failure
FAILED to find BLiFF++
is it necessary or is IT++ ok
ok so i looked at the cmakelist.txt in openvibe-plugin/classification-gpl/trunc
there is INCLUDE("FindThirdPartyBLiFF")
so i looked at the FindThirdPartyBLiFF.cmake to see where they would be looking for BLiFF++.
according to what i have seen in it the script is looking for a Trial.h file.
can I put in static the path to BLiFF ?
it is normal that the BLiFF dependency is not found. It is not necessary for OpenViBE and it is NOT supported by our team.
As for your problem, can you please check the log file in scripts/software/log/native-packages.log ? I am currently installing openvibe in ubuntu 10.10 to see where could be the problem.
actually i don't have this log
i have
boost.log cegui.log lua.log ogre.log ois.log vrpn.log
I work on 10.04 LTS
i have
I work on 10.04 LTS
ok so i cleaned and i rebuilt and it works.
It must have been files that didn't compile correctly.
so thank you for your help and sorry for the inconvenience.
