Page 1 of 1
CSV Import
Posted: Mon Jul 01, 2013 12:12 am
by krisp
I see CSV import mentioned here
http://openvibe.inria.fr/documentation/ ... eader.html but only see CSV export in the the designer. Am I overlooking it?
Re: CSV Import
Posted: Mon Jul 01, 2013 8:41 am
by jtlindgren
Tick 'show unstable'.
Cheers,
Jussi
Re: CSV Import
Posted: Mon Jul 01, 2013 4:37 pm
by krisp
Ahhhh. Much obliged.
Re: CSV Import
Posted: Mon Jul 01, 2013 11:30 pm
by krisp
I can get live visualzations to run using my Neurosky headset, but not play back data I recorded on my android (using EEGID for this test). I have two boxes, the CSV File Reader and Signal Display visualization, load the CSV and hit start which pops the window but with no data. So is this a problem with the CSV data I am using or my workflow?
Re: CSV Import
Posted: Thu Jul 04, 2013 4:19 pm
by jlegeny
Signal display should be able to display data from a CSV file. How is your data formatted in the file? Can you give us an example here?
