CSV Import
CSV Import
I see CSV import mentioned here http://openvibe.inria.fr/documentation/ ... eader.html but only see CSV export in the the designer. Am I overlooking it?
Re: CSV Import
Tick 'show unstable'.
Re: CSV Import
I can get live visualzations to run using my Neurosky headset, but not play back data I recorded on my android (using EEGID for this test). I have two boxes, the CSV File Reader and Signal Display visualization, load the CSV and hit start which pops the window but with no data. So is this a problem with the CSV data I am using or my workflow?
Re: CSV Import
Signal display should be able to display data from a CSV file. How is your data formatted in the file? Can you give us an example here?
