Pickku,pickku wrote:thankyou for reply sir.I tried as you told changing to comma in channel selectors but it is not working.You told its working for you can you send the file and design to me.
you do not change the comma in channel selectors. you change to comma by double clicking on the csv file reader box. there you have to change the separator field to ',' if your csv file is using ','.
Hope this helps
