Using Matlab with OpenViBE
KedarPs
Post by KedarPs »
Hello Everyone,
I am a new OpenViBE user and interested in using OV with Neurosky's Mindset dry electrode system. First of all let me first commend the efforts taken in making OpenViBE, it is really well made and quite easy to use as well :D . I am interested in using OV with Matlab, however I am having some issues with getting Matlab to work. I am using Windows 7 (64-bit) with 32-bit Matlab R2012b installation.
I am primarily using the tutorial given in http://openvibe.inria.fr/tutorial-using ... -openvibe/ and I was successful in building the Matlab plug-in but I could not get the tutorial to run. Here are the details:
To Build:
I added the following in win32-dependencies.cmd
SET OV_DEP_MATLAB=c:\Program Files (x86)\MATLAB\R2012b
and in win32-dependencies.cmd
SET PATH=%OV_DEP_MATLAB%\extern\lib\win32\microsoft;%PATH%
to provide path to libmex.lib, libmx.lib and libeng.lib.
I get the following output in the console after running win32-build.cmd:
Configuring and building openvibe-plugins\matlab\trunc ...
--   Found OpenViBE...
--     [  OK  ] lib C:/Users/ksp6/Documents/OpenViBE/openvibe/trunc/lib/OpenViBE-dynamic.lib
--   Found OpenViBE-toolkit...
--     [  OK  ] lib C:/Users/ksp6/Documents/OpenViBE/openvibe-toolkit/trunc/lib/OpenViBE-toolkit-dynamic.lib
--   Found OpenViBE module System...
--     [  OK  ] lib C:/Users/ksp6/Documents/OpenViBE/openvibe-modules/system/trunc/lib/OpenViBE-module-System-dynamic.lib
--   Found OpenViBE plugins global defines...
--   Found Matlab [C:/Program Files (x86)/MATLAB/R2012b/bin/matlab.exe]
--      [  OK  ] Third party lib C:/Program Files (x86)/MATLAB/R2012b/extern/lib/win32/microsoft/libmex.lib
--      [  OK  ] Third party lib C:/Program Files (x86)/MATLAB/R2012b/extern/lib/win32/microsoft/libmx.lib
--      [  OK  ] Third party lib C:/Program Files (x86)/MATLAB/R2012b/extern/lib/win32/microsoft/libeng.lib
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/ksp6/Documents/OpenViBE/local-tmp/openvibe-plugins/matlab/trunc
Copyright (C) Microsoft Corporation.  All rights reserved.
[100%] Built target OpenViBE-plugins-matlab-dynamic
Install the project...
-- Install configuration: "Release"
-- Up-to-date: C:/Users/ksp6/Documents/OpenViBE/openvibe-plugins/matlab/trunc/lib/OpenViBE-plugins-matlab-dynamic.lib
-- Up-to-date: C:/Users/ksp6/Documents/OpenViBE/openvibe-plugins/matlab/trunc/bin/OpenViBE-plugins-matlab-dynamic.dll
Running the Tutorial:
I was trying to test the share/openvibe-scenarios/box-tutorials/matlab/tuto1-signal-filter.xml but could not get it to run successfully.
I ran ov-designer.cmd and loaded the project. I can see that OV loads the matlab-plugin:
[  INF  ] Added 2 plugin object descriptor(s) from [../bin/OpenViBE-plugins-matlab-dynamic.dll]
I also added the respective Matlab-path executables and Matlab working directory paths, but when I hit play I get the following error saying that it could not load the matlab engine.
[ ERROR ] At time 0.0 sec <Box algorithm::Signal filter> First call to MATLAB engine failed.
        To use this box you must have MATLAB (32 bits version) installed on your computer.
[WARNING] Box algorithm <Signal filter> has been deactivated because initialization phase returned bad status
I would appreciate if you'll could help me in anyway. Thanks in advance.
-Kedar
KedarPs
Re: Using Matlab with OpenViBE
Post by KedarPs »
Ok I think I got this one. I realised that in the Matlab executables path and the working directory path, you have to enter a '\' at the end of the path. e.g.
This path is invalid:
C:\Users\ksp6\Documents\OpenViBE\dist\share\openvibe-scenarios\box-tutorials\matlab
However this one is: (Note the additional '\' at the end of the path)
C:\Users\ksp6\Documents\OpenViBE\dist\share\openvibe-scenarios\box-tutorials\matlab\
Thanks though. And sorry for the previous post being so long.
-Kedar.
jlegeny
Post by jlegeny »
Hello KedarPs,
thank you for mentioning this issue, we will look at it to make this more user friendly in the next release.
toncho11
Post by toncho11 »
Also when setting the folders in the Matlab script box in the designer it is important to:
1) use "/" instead of "\"
2) use DOS names for "Program files" and similar long paths:
C:\Program Files = C:\Progra~1
C:\Program Files(x86) = C:\Progra~2
-Anton
Haneen
Post by Haneen »
Where can I find win32-dependencies.cmd ?
I am facing the same problem actually :)!
In 0.15.0 prepackaged distributions its in dependencies\ under the openvibe install folder and called set-env.cmd. For source packages the file is created by the dependency installer .exe and is located in scripts\. We're currently working on related parts so expect SVN version to be possibly a little different again.
