ssvep
Posted: Tue Jul 31, 2012 9:00 am
Dear Openvibe
I tried to run SSVEP scenario in Openvibe 0.14.0 using Emotiv headset. When I ran ssvep-bci-1-ssvep-configuration.xml, the warning messages showed that
Thank you in advance
-Jim
. Then, when I tried ssvep-bci-2, the program terminated.[ INF ] At time 0.211 sec <Box algorithm::Experiment Settings> <In Script> Writing file '../share/openvibe-scenarios/bci/ssvep/configuration/temporal-filter-freq-1.cfg'
[WARNING] At time 0.211 sec <Box algorithm::Experiment Settings> Lua error: .../ssvep/scripts/configuration-experiment-settings.lua:70: attempt to index global 'cfg_file' (a nil value)
[ INF ] At time 0.211 sec <Box algorithm::Experiment Settings> Lua script terminated
-Jim
