running OpenViBE on ubuntu 9.04
mati
Post by mati »
Hello, I have a problem with running OpenViBE on ubuntu 9.04 with gnome.
I`ve installed the system from sources using scripts/linux-build and it went OK.
A moment after running scripts/linux-test I`m being logged out of my linux session.
I`ve tracked log from the standard output, but I can`t see any hints from this about what might be wrong. I thing I`ll need some help from You...
Below I`m pasting the log:
/lib/openvibe/trunk/scripts ~/lib/openvibe/trunk/dist/bin
[  INF  ] Created kernel loader, trying to load kernel module
[  INF  ] Kernel module loaded, trying to get kernel descriptor
[  INF  ] Got kernel descriptor, trying to create kernel
 You chose the VR application
 [tie-fighter]
~/lib/openvibe/trunk/dist/share/openvibe-applications/vr-demo/tie-fighter ~/lib/openvibe/trunk/dist/bin
No language selected. Default is: english (eng).
  _                       _
 | |     _.'\   /'._     | |
/  b__--- | .'"'. | ---__d  \
\  p""---_| '._.' |_---""q  /
 |_|                     |_|
Tie-fighter application started !
May the Force be with you, young padawan.
0xbffaf0e1
[[00m[00m[32m  INF  [00m] Adding configuration file(s) [[00m[00m[35m../share/openvibe.conf[00m]
[[00m[00m[32m  INF  [00m] Adding configuration file(s) [[00m[00m[35m/home/mati/.openviberc[00m]
[[00m[00m[32m  INF  [00m] Adding [[00m[00m[35m../lib/libOpenViBE-plugins-*.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m2 (0x2)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-acquisition-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m5 (0x5)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-classification-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m1 (0x1)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-classification-gpl-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m1 (0x1)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-feature-extraction-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m13 (0xd)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-file-io-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m8 (0x8)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-samples-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m24 (0x18)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-signal-processing-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m19 (0x13)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-signal-processing-gpl-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m16 (0x10)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-simple-visualisation-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m10 (0xa)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-stimulation-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m18 (0x12)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-stream-codecs-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m1 (0x1)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-streaming-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m4 (0x4)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-tools-dynamic.so[00m]
[[00m[00m[32m  INF  [00m] Added [00m[00m[35m2 (0x2)[00m plugin object descriptor(s) from [[00m[00m[35m../lib/libOpenViBE-plugins-vrpn-dynamic.so[00m]
lbonnet
Re: running OpenViBE on ubuntu 9.04
Post by lbonnet »
Hello mati, and welcome on board !
This problem may come from a server X failure.
You should check if your graphic card has up-to-date driver.
In addition, we don't support anymore the Ubuntu 9.04.
I am sorry but the operating system support list in the FAQ is not updated.
We officialy support the Ubuntu 10.04.
Please update your system, and come to us if you still experience this problem.
Best regards
-Laurent
In addition to what Laurent said, Ubuntu 9.10 is still supported... But Ubuntu 9.04 is not supported anymore.
