build driver
Come here to discuss about OpenViBE in general!
Post Reply
iuri
build driver
Post by iuri »
Hi there,
I have an EMG machine and i want to use on openvibe.
How and where do i start?
What do i need to create the driver?
what kind of specifications?
lbonnet
Site Admin
Re: build driver
Post by lbonnet »
Hi iuri,
If you want to create a new driver, I suggest that you read the developer tutorial.
Of course, you can look at the existing drivers for concrete examples.
A second tutorial can teach you how to configure a new driver.
To create a driver, you have to know how to communicate with your device.
The simplest way comes when the manufacturer gives you a SDK to work with (example: the VAmp driver).
Sometimes you will have to directly communicate through USB or Serial Port. In this case you need the precise protocol used to communicate with the device.
I hope this helps,
Feel free to ask any question if the tutorials need more details,
Laurent
Post Reply
