i would like to add this snapshot for help people to understand my problem.
connection between OpenVibe
Re: connection between OpenVibe
- capture.JPG (125.21 KiB) Viewed 5457 times
Dear yannick,
we got similar problems in the past, it happened when the filenames were too long. Could you move the sources in |i]c:\openvibe[/i] instead of c:\openvibe-0.5.0-svn1827-src\openvibe-0.5.0-svn1827-src ?
This should solve the problem.
Damn windows limitations !
Dear Yann,yrenard wrote:Dear yannick,
here is the sample program. For your information, you can find its sources from the standard VRPN release 07.13 (It should still be present in more recent releases).
You should use it in a console this way :
e.g.Code: Select all
vrpn_print_devices peripheral_name@host_name
You should read the analog / button status as they change in time.Code: Select all
vrpn_print_devices openvibe-vrpn@localhost
Tell me if it works. If it does not, please dump the console messages so I can see what happens.
Can I have the source of that program? I'm currently developing a connection from openvibe to an external device using vrpn under Ubuntu Lucid Lynx 10.04, but due to my lack of experience in C programming, I found difficulties in understanding how to implement vrpn client. Your program source would be very helpful.
Thank you.
Dear ariandy,
this code is surely available as part of the official VRPN package !
Just look at the vrpn/client_src folder in the vrpn_07_15.zip archive
Oops, sorry, didn't check throughyrenard wrote:Dear ariandy,
Thanks BTW
oops.. sorry, post deleted. changed my mind.
