I have downloaded openvibe´s source code in order to start working with it, and I wonder if I can get the GUIs related to them as well. Are both (sources and GUIs) programmed in the same language?
Thans,
Lorena
Source code
Re: Source code
Hi Lorena,
The GUI files are .ui Gtk files (written in an XML format).
They are located in the share folders of the projects.
For example, the Designer GUI is in openvibe-applications/designer/share.
These files can be read by glade.
They are uses as a basis for the GUI, but many things are done in the C++ source code (like modification of the widgets to add/remove items, or signal connection to attach an action to a button).
The code is written using the Gtk library.
