I'm currently trying to use the software via the newly updated version, yet when I click the openvibe-designer.cmd, it says that I caught an exception at the very top, which prevented from executing the application. Unfortunately there is no warning or error that I have encountered especially when looking at the cmd below. I hope that you guys have an idea on what I've currently encountered. I am also trying to build it, however after installing the dependencies and adding the Eigen3, I am stuck with the build.cmd as it search for GTest, but that would be for another post.
[ INF ] Kernel module loaded, trying to get kernel descriptor
[ INF ] Got kernel descriptor, trying to create kernel
[ INF ] Adding kernel configuration file [C:/Program Files/openvibe-3.1.0-64bit//share/openvibe/kernel/openvibe.conf]
[ INF ] Adding plugins from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-*.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-acquisition.dll]
[ INF ] Added 3 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-artifact.dll]
[ INF ] Added 3 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-classification.dll]
[ INF ] Added 2 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-contrib-file-io.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-contrib-misc.dll]
[ INF ] Added 2 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-contrib-network-io.dll]
[ INF ] Added 4 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-contrib-pybox.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-contrib-python3.dll]
[ INF ] Added 15 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-contrib-signal-processing.dll]
[ INF ] Added 3 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-data-generation.dll]
[ INF ] Added 17 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-designer-advanced-visualization.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-designer-examples.dll]
[ INF ] Added 3 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-designer-simple-visualization.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-dll-bridge.dll]
[ INF ] Added 6 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-evaluation.dll]
[ INF ] Added 5 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-examples.dll]
[ INF ] Added 2 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-features-selection.dll]
[ INF ] Added 8 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-file-io.dll]
[ INF ] Added 3 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-games.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-matlab.dll]
[ INF ] Added 3 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-network-io.dll]
[ INF ] Added 7 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-riemannian.dll]
[ INF ] Added 10 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-classification.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-data-generation.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-feature-extraction.dll]
[ INF ] Added 11 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-file-io.dll]
[ INF ] Added 25 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-signal-processing.dll]
[ INF ] Added 6 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-stimulation.dll]
[ INF ] Added 20 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-stream-codecs.dll]
[ INF ] Added 2 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-streaming.dll]
[ INF ] Added 4 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-sdk-tools.dll]
[ INF ] Added 18 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-signal-processing.dll]
[ INF ] Added 10 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-simple-visualization.dll]
[ INF ] Added 9 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-stimulation.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-streaming.dll]
[ INF ] Added 1 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-tests.dll]
[ INF ] Added 2 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-tools.dll]
[ INF ] Added 4 plugin object descriptor(s) from [C:/Program Files/openvibe-3.1.0-64bit//bin/openvibe-plugins-vrpn.dll]
Caught an exception at the very top...
Leaving application!
