MindWave Mobile 2 and Acquisition server problems
Posted: Mon Oct 14, 2019 6:23 am
Hi,
I have browsed the forum without finding any definitive answer to my problem.
All the attempts I made to connect the MindWave Mobile 2 headset to the OpenVibe acquisition server (changing COM port number, reinstalling Thinkgear connector ...) lead to the same messages :
The MWM2 device works very well with other dedicated software on my PC with the same BT interface (not at the same time obviously).
All ideas to help solving my issue ?
Thank you very much for your help.
Regards
Code: Select all
Scanning COM ports 1 to 16 ...
The driver was unable to find any valid device on serial port COM1 to COM16
Connection failed ...
Regards
