It is currently Fri Feb 28, 2020 8:50 am
PostPosted: Thu Apr 03, 2014 9:33 am
"R&D Engineer for improving real-time software performance of Brain-Computer Interfaces”
An engineering position is open at Inria, Rennes, France, within the frame of the SABRE collaborative project. The SABRE project aims to attain advances in Brain-Computer Interfaces (BCI) by proposing novel, efficient algorithms for processing electrical signals of the brain (EEG). The project notably focuses on solving the complex inverse problem in real-time: inferring the likely electrical sources given EEG measurement data from a dense array of electrodes. The inferred source signal estimates are then used for visualization and classification of cerebral activity, and for device control -- online, in real-time.
The selected engineer will work on implementing real-time C++ versions of the algorithms proposed during the project and designing them in the scope of the OpenViBE real-time neuroscience framework (http://openvibe.inria.fr). The engineer will also work on extending the OpenViBE kernel and architecture as required for this purpose, and develop real-time brain data visualizations for the project. The engineer may also be requested to work on data acquisition, associated BCI protocols and diagnostics and run the related experiments.
The main implementation language of the project is C++, although experimental prototyping may be carried out in Matlab or Python.
Application deadline: 22.Jun.2014
Target hiring date is Sep/Oct 2014.
Please see here for the full announcement:
http://openvibe.inria.fr/openvibe/wp-co ... gineer.pdf
PostPosted: Mon Jun 23, 2014 11:29 am
The deadline has been reached for applications and the position can no longer be applied to.
Americanized by Maël Soucaze.
