Build Instructions
NB: Document last updated for OpenViBE 3.6.0.
Older versions:
1. Getting the sources
From archive
An archive of the sources is available on the downloads page.
Important: When extracting the source archive, the directory path must NOT contain any spaces or special characters such as whitespace, &, |, (, ) etc.
  • Good example : C:\work\openvibe\
  • Bad example (blanks) : C:\Program Files\openvibe
On Windows, we recommend to keep the path as short as possible or you may run into compiling problems.
From Gitlab
You can clone OpenViBE repository with the following command:
git clone --recurse-submodules git@gitlab.inria.fr:openvibe/meta.git
2. Setting up environment
Install miniconda
install miniconda: https://docs.conda.io/projects/miniconda/en/latest/ (for Windows, use a powershell for the following steps).
setup virtual environment
From the top level of the source directory, run the following command in order create a virtual environment with all necessary dependencies to build OpenViBE:
conda env update -f conda/env_{linux|osx|windows}.yaml
3. Building OpenViBE
On Windows
The commands detailed below need to be executed in a Powershell command prompt.
The following steps assume that you have installed Visual Studio 2019
Setup Visual studio in prompt
In order to setup Visual Studio compiler in your Powershell prompt, run the following commands:
$vsPath = &"${env:ProgramFiles(x86)}\Microsoft Visual Studio\Installer\vswhere.exe" -version '[16.0,17.0)' -products * -requires Microsoft.VisualStudio.Component.VC.Tools.x86.x64 -property installationpath
Import-Module (Get-ChildItem $vsPath -Recurse -File -Filter Microsoft.VisualStudio.DevShell.dll).FullName
Enter-VsDevShell -VsInstallPath $vsPath -SkipAutomaticLocation -DevCmdArguments '-arch=x64'
Build OpenViBE
From the top level directory of the sources, create a build folder, and build OpenViBE with the following commands:
mkdir build; cd build
cmake .. -G Ninja
ninja -j 4
On Linux and MacOS
From the top level directory of the sources, create a build folder and build OpenViBE with the following commands:
cmake ..
make -j 4
4. Running OpenViBE
The built applications are located in the build, under the bin/ folder. You can therefore launch the designer with the following:
./bin/openvibe-designer
Running tests (Optional)
The SDK tests can be run with the following:
  • Unit Tests
cd sdk/unit-test ; cTest -T Test --output-on-failure ; cd ../..
  • Validation Tests
cd sdk/validation-test ; cTest -T Test --output-on-failure ; cd ../..
The Extras tests can be run with the following command:
cd extras; cTest -T Test --output-on-failure ; cd ..
This entry was posted in Uncategorized. Bookmark the permalink.
